Henger woes
Wow! Thank you!
They certainly appear the same... I'll whip mine off in a while and measure it. They are a bit crude in all honesty, so perhaps the measurements aren't that crucial....we shall see!
Again, beyond the call of duty!
Thank you!
Edit : Told you they were bloody silly little things! Just got the existing one off, and gave it a quick measure...I suppose it could be a tad squashed through use, but it looks circa 30mm tall, and about the same at its fattest point. Hole at the base is about 15mm diameter..
It looks to be about 31mm in every direction. But the hole in them looks to be 20mm.
Hmmm... thinks....I should've scribbled these down at the time, maybe?
Just put the thing back, but there's only 6 screws to remove to get the arm uncovered and access the bulb anyway!
Back later, methinks!
Thanks again.
Excuse the David Bailey photographic attempts!
The hole in the metal plate - through which the bellows open end is pushed - is about 18mm diameter.
The actual opening in the bellows does appear to be 15/16mm....but is 20mm wide including the rubber ring surrounding it!
