Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 76
(changed the title to reflect the content better)
I need a spot of info for a conversion project...
This is about the Elektra Bekum/Metabo KGS3xx series, or the Axminster QMS254I (which is almost identical). These are they:
Mine is old but good, and I want to add an electric brake to it. Later 240V ones and the Axminster one have a brake, but there are several possible designs and I'm not sure which type has been fitted. The simplest approach is a high-power, low-resistance shunt resistor, across the stator winding when the saw is OFF, but this requires a double-pole changeover switch for the trigger, not a make-break one such as mine has. I'm guessing that's what the later saws have, rather than a complicated circuit, in which case it's a relatively easy mod to do to mine.
If the later versions have this sort of brake, it's easy to get the switch as a spare part and build the rest.
So if you've dismantled your saw, for a good clean, perhaps, does the trigger for yours have six wires going to it (to separate terminals), or just four?
Thanks to anyone who knows and can tell me!
Regards,
E.
PS: To avoid any argument breaking out, this is NOT a safety mod at all. It simply stops the blade a bit more quickly, to speed up setup time when making multiple cuts. Stopping an SCMS too fast is inherently dangerous if designed like mine - I'm aware of the issues!
PPS: If I can do this, I'll post pictures in due course.
Regards,
E.
