Jonm
Those brick panels look fairly tall and are effectively free standing. You have to be sure they do not fall over, I doubt that single skin would be adequate.
Pen and paper drawing from a computer engineer ?This is how i imagine it to be. It is all for decoration purposes really.
That would certainly transfer some of the loading to light duty posts not intended for this function. The proposed structure is high enough to require planning permission for it to go ahead as proposed.Maybe screw in stainless ties into the oak every few courses would be helpful?
If this construction goes ahead it could cause some upsets in usual UK windy weather. Each infill panel may experience a total wind loading of between 1500 and 1600 pounds. It may be necessary to have a builders skip on site for a quick clear up.
I would agree, if single skin with no support and not tied in at the sides, first time anyone leans on the wall it will collapse. You would be much better off to use wood or maybe something like wicker if you want a rustic look.Those brick panels look fairly tall and are effectively free standing. You have to be sure they do not fall over, I doubt that single skin would be adequate.
I agree with your first recommendation, it'll be much simpler and quicker. Nice one.Give up, as I doubt you’ll be able to do that.
Rip it in half, cut the necessary half channel and glue back together.
Or just cut a groove the width of the T and machine infill strips to neck the groove.
Why do you need to do this?
mmmmm I agree..................My advice is to give up and drink gin and tonic.
