G S Haydon
- Joined
- 24 Apr 2013
- Messages
- 1,667
- Reaction score
- 223
Corneel, agreed, I think thin plane irons lend themselves well to honing the whole bevel.
Not common but they are certainly there. Unless you are a window fetishist like me they are easily overlooked. In fact the last proper sash I did was on the Chatsworth estate which copied the 18C originals which had bevels instead of mouldings. Thin 14mm glazing bars so quite slender and elegant.G S Haydon":24jr6t5q said:I must confess Jacob here in the South West it is very rare to find anything made before WW 2 that had anything but Ovlo or Lambs Tongue mouldings. ....
I didn't work at Plas yn Rhiw I was just a visitor! But I have done period work in a lot of very nice old houses.G S Haydon":1wxs919i said:Very nice Jacob! These type of conservation projects are lovely to be part of.
AndyT":n5w05vtm said:If anyone thinks they have read enough about sharpening but quite fancies learning a bit more about sash templates... get on over to the excellent "Hackney Tools" blog here: http://hackneytools.com/2013/08/how-to-use-sash-templates-or-templets/ and look for the dowloads.
Gary asked the right people and now has a copy of an article by Jane Rees (yes, the tool historian who is working on the next edition of "British Planemakers") which explains what types there were and something of how they would have been used. The article was published in the Journals of the Construction History Society and the Early American Industries Association, but has not been available in full online before. You can download it as a pdf.
I thought I had linked to this before, but a search shows that I hadn't - I hope people will think of it as a reward for staying with this thread as far as page 14!
I know what I know, no more no less and I don't try to pretend otherwise. I couldn't get away with it could I with my little archivist troll trailing after me day and night! :roll:mark w":2p4sbov0 said:Jacob I think the point Bugbear was trying to make with regard to the sash template was, you try to make out you know a great deal on a subject to the point of knowing everything when in fact you don`t,
It doesn't mention grindstones. Can you not read? It mentions "grinding basils" but in the absence of a wheel that'd be hand done on a flat stone. So I wasn't wrong. Have another look.another example is your comment on Ellis when you said he doesn`t say much about sharpening, no mention of grindstones and then Bugbear pastes Ellis`s article which is fairly long and detailed and has reference to a grindstone! You couldn`t have been more wrong.
The chisel which you would most likely "push into a piece of wood" is the mortice chisel which has a rounded bevel for a good reason. For most chiselly purposes it isn't going to make much difference, except an overly hollow grind is going to be more fragile.Answer this question, which is easier to push into a piece of wood, a sharp chisel with a convex bevel or one with a concave bevel?
Weirder and weirder!when someone like Bugbear catches you out you simply ignore the point they are making.
FFS I knew nothing about Fenders and was quoting something I'd read and somebody who knew more than me put me right. So what? Is that it then? What on odd and uninteresting little thing to remember. Do you have link? we could all go back for a second look and get really excited. Here it is post798586.html?hilit=fender#p798586mark w":2plgmwr3 said:I think you do pretend Jacob, you were caught out in another thread when you made some reference to guitars, a person who really new the subject tried to put you right.
Oh I see. By "grindstone" I meant wheel. There's no mention of "grindstones" or "grind wheels" or hollow grinding etc etc.which is the obvious but trivial point I was making, which you have chosen to misunderstand .In bugbears text it says this "An undulating motion must be avoided,as this will produce a "round edge", necessitating frequent regrinding". what is he grinding on if not a stone? Yes I can read.
:roll: What chisel would you use for splitting hairs?The chisel you are most likely to push into a piece of wood is the paring chisel, you are far more likely to strike a mortice chisel with a hammer.....
Deeply fascinating as usual Pete. Where would we be without your unceasing wit and wisdom? Never a dull word. :roll:Pete Maddex":2mxij6bc said:I think he believes he is infallible, and because he make things he is so much better than any one else on here.
Probably small man syndrome and overlooked middle child/only child syndrome.
