Saddle and slides 3
With the cross slide mods complete, I made a new sheet steel insert to cover the front of the screw, thinning a section immediately above the gear on the left as clearance is very thin. This plate is removable so that I can slide it forward to access the oiling hole for the screw's plain bearing, but keep that covered otherwise.
The bed was cleaned and the rack removed for cleaning then replaced
Then refit the slide, bolt the apron back on, thread the two shafts through the apron and reseat them in the gearbox.
Finally bolting the right hand bearing block in place.
