Jacob
What goes around comes around.
Different game altogether. Personally I'd use a sanding disc on the outboard end of the headstock or a belt sander.
Dino":2vwfmzan said:I think I'll work on getting to do it by hand. A user said in another thread that I'd need a way to sharpen my gouges and chisels for woodturning, would I not be able to do these by hand as wel or do they require a machine too?
Yes, a standard bench grinder is fine for turning tools, and is pretty much what most turners use (especially those with limited budgets).Dino":1fcqewv5 said:I assume I'd be able to use the bench grinder as part of that set up?
Dino":ptlopd2e said:I've recently bought a used spokeshave and hand plane, the first I've ever used, as well as some used chisels.
I'm looking for some sharpening tips as well as some general usage tips as when I cut with them they are not taking the wood off "cleanly" - the shavings are tearing off rather than being shaven off.
Am I sharpening at the wrong angle? Am I not using a high enough grit? (I have a 600 grit diamond sharpening stone).
Thanks.
Which is fine if you can do that, but when starting out those skills are unlikely to be in place. Why make beginners lives harder by suggesting they have to learn two skills ? Especially if not getting sharpening correct makes the second task of turning wood much harder.If you can put a turning tool to a piece of wood and produce a controlled precise shape freehand you can put that same tool to your grinding medium and do the same to the tool.
Jacob":adrjr2du said:If you can put a turning tool to a piece of wood and produce a controlled precise shape freehand you can put that same tool to your grinding medium and do the same to the tool. One is almost a mirror of the other.
The same applies if you use a jig.Spindle":2g1dant6 said:Jacob":2g1dant6 said:If you can put a turning tool to a piece of wood and produce a controlled precise shape freehand you can put that same tool to your grinding medium and do the same to the tool. One is almost a mirror of the other.
Hi
I disagree - when a tool is used in turning it's effect is immediately apparent and can be adjusted accordingly unlike applying a turning tool to a grinding wheel where the effect is hidden until the tool is turned over to allow observation of the bevel.
But the jigs themselves are so variable and involve a learning curve and time spent making them.I'd advise anyone starting out in woodturning to use some form of jig to allow repeatable, single bevel grinds to be produced and thus remove one of the variables encountered when learning to turn.
Regards Mick
Random Orbital Bob":3o2wb4so said:Jacob......has the word "progress" ever permeated that oh so traditional mind of yours?
No it isn't - it's a tool rest. It's in the name - look closely, there are two words; TOOL and REST.Spindle":2c8hjcwg said:...- after all that tool rest is a jig isn't it :roll: :roll:
Regards Mick
Jacob":jyr5qmwy said:A copy lathe is "progress" too. Why struggle without?
I don't think it is progress to deskill these crafts. Quite the opposite - it's craft in decline.
The only variability in the one I pictured above is the wear on the wood and wheel. The ear on the wooden part is neglibible and the change the wheel diameter is so slow you won't notice it until you've done a huge amount of tool sharpening.Jacob":mw6comff said:But the jigs themselves are so variable and involve a learning curve and time spent making them.
Nor did electric motors or high speed steel tools, but most people use them now. It's called progress.Jigs don't feature in old turning books.
Jacob":2mdi2fe6 said:No it isn't - it's a tool rest. It's in the name - look closely, there are two words; TOOL and REST.
