Fromey
A while back I purchased a Lynx handsaw (rip cut, 22" long, 4.5 tpi) from Thomas Flinn & Co. Just the basic beech handle, not the more expensive walnut handle.
It's a nice looking saw and the tapered ground saw plate is very noticeable and satisfying to see.
They are advertised as, "precisely set and sharpened", so I expected this bit of Sheffield steel/manufacturing to work very well. I also knew that rip sawing is never going to be easy and that you will always break a sweat after a while, so I don't think I have unrealistic expectations of hot knives and butter.
However, I think there's something wrong with the saw as sawing with it is no picnic :? I think I've got a reasonable sawing technique, and I've used the saw on a number of pieces of wood so far (mainly cherry). However, the saw constantly sticks/catches. Bees wax on the saw plate helps a bit, but not that much. In addition, and this really has me suspicious, after I've sawn down a few few inches and established a good kerf, I find I can't get the saw plate all the way through the kerf and thus do full-length sawing. About 3/4 of the way along the plate, it jams as if the set is too much there. I've looked down the teeth and can't by eye notice a difference in the saw set other than the last tooth before the handle is way out.
Did I buy a dud? Is this actually normal and I just don't have the muscle? Are you supposed to rip saw only in one direction to the grain like planing?
I have a new snazzy HD camcorder, so I might try a Youtube video this weekend to show better what the problem is.
