NopeDon't you have a tractor and plough yet?!![]()
Ok, will get a photo tomorrow in the daylight.Send us a pick @baldkev - it speaks a thousand words.
For reference , this was a new build 22 years ago - with hindsight i would have dug it up!!!! I did pay "in bacon sandwiches" the guys that laid the lawn, but they did a minimal job, and I have always been battling against this
Grit and hardcore is the worst thing to add if you mix it with the soil- too many tv gardeners advise it but it’s not right. It reduces the flow of water through the soil as it has to go round the stones, and the stones don’t hold any water so until you get up to over 70% gravel by volume it makes drainage worse.if it's clay you can also dig in some grit / hardcore etc to help aerate it.
Trouble is if you don't add structure to it it will compact down again quicker
It sounds like you have clay soil and you may have shifted the soil around leaving more subsoil than top soil on the surface. Subsoil is not a good plant medium. Before you spend too much, you could dig over the ground and, at the same time, dig in some soil improver (from the garden centre) allowing a 3 inches (75mm) layer on top before digging it in. Adding horticultural sand and grit would also help; it would help to break up the soil and improve drainage. Good luck.Hi, i have a grass problem ( garden variety )
About 3 years ago i did some work in our garden moving a bank and levelling. I had a mini digger and power barrow in there.
Once the soil was level, i raked over it and laid turf, watered etc...
It took hold just fine. With last years heat, the majority of it died off, plus it does tend to get waterlogged despite being on a hill. I think i must have comoacted the ground using the machines and now it doesnt drain well. Ive been round with a fork punching holes in the garden at the start of last year, but no change other than the heat finally killing it.
At the moment we have a mud bath, not a garden.... whats best? Do i get a rotavator and churn it up? Then new turf?
Im not green fingered in the slightest, i even manage to kill mint plants each year![]()
Organic matter also retains moisture. Sand improves drainage and, together with grit/stones will help break up clay.Grit and hardcore is the worst thing to add if you mix it with the soil- too many tv gardeners advise it but it’s not right. It reduces the flow of water through the soil as it has to go round the stones, and the stones don’t hold any water so until you get up to over 70% gravel by volume it makes drainage worse.
Organic matter will increase the moisture capacity of the soil and help with drainage to an extent. If water is pooling then it’s probably a clay sub soil that won’t drain quickly. Solution would be french drains and/or a soak away.
I’d try organic matter first as easier to add and mix through with topsoil than the effort involved with digging in drains.
I agree, although I doubt farmers would add sand and grit as it would be too expensive for large fields.Quick soil test: take a pinch, wet it and rub it between the fingers. If it feels silky with no grittiness you've got pure clay. If it's slightly gritty and smears dark brown it's loam, and if very gritty a sandy soil. Add a few drops of vinegar, if it foams it's chalky soil. There's all sorts of levels in between but that will give you the basics.
There's no point adding gravel/sand. If it worked you'd see farmers doing it, but they put muck on so organic matter is the way to go. It breaks down to form humus, and humic acid binds clay particles, improving soil structure and field holding capacity for water. Lime and magnesium can help open clay soil but it's not advisable to add them at the same time as muck or soil improver as they'll release the nitrogen you want in the soil as ammonia gas.
Double digging (also known as 'barsteward trenching') means digging a trench one spades' depth, putting that soil to one side, turning over the bottom of the trench, then repeat with the next trench across your area. It'll break open the soil to 16 inches or so.
Edit to avoid filter changing meaning
Stones will only improves drainage once you get over 70% below that it impedes drainage and moisture holding capacity. It goes against commonly accepted tv wisdom but part of my degree included soil science at the institute for grassland research. We made mixes and put them through lab conditions to measure drainage. Stones make it worse as the water has to drain around them lengthening the path the water has to take through the soil, slowing it down. Think concrete- the cement fills the voids around the aggregate, it doesn’t stay as free space unless you have loads of aggregate and start to introduce voids.Organic matter also retains moisture. Sand improves drainage and, together with grit/stones will help break up clay.
walkies ?OK.....
woof woof.
Sorry, I'll get me coat.
Actually not so good for soil as is sawdust. When it breaks down it uses up the nitrogen and the soil is worse.Bark
Yep, that's why i dont eat humus despite delia smith claiming its niceQuick soil test: take a pinch, wet it and rub it between the fingers. If it feels silky with no grittiness you've got pure clay. If it's slightly gritty and smears dark brown it's loam, and if very gritty a sandy soil. Add a few drops of vinegar, if it foams it's chalky soil. There's all sorts of levels in between but that will give you the basics.
