Maia28
It feels like its nearly there now and I have started thinking about benches, electrics and such like. Since my last post, progress seems to have been relatively quick. Because the jobs are now mostly inside, I can do a few bits in the evenings. So, I have filled the walls with 100mm insulation which was mostly left behind by my builders in the summer. I ended up a few m^2 short, but B&Q have a 2 for 1 offer at the moment so the roof space now has at least 270mm of insulation.
I have also fitted the windows and frames. Again, these where removed from the house when the extension was built and I have chopped the plastic frames in half and mounted them horizontally. The window frame to the right is made from two old uPVC frames joined in the middle. I got the openings slightly wrong and had to use a router to remove the groves from around the edges - the plastic snow goes everywhere.
Using some old 3/4" ply and left-over cladding, I knocked up a barn door. I'll have to remount this at some point as I didn't get the hinges quite right. I also used left-over cladding to fill the soffits, and have some other pieces to make sills for the windows from.
Putting up the membrane inside seems to take longer than it should and I had to buy a new stapler as the old one literally exploded. The new one also fires pins which has come in handy for holding up cladding on the ceiling which I started doing today.
I have lined the inside with 1/2" ply and also installed the fuse box and an earth rod. I have also given the outside a coat of creosote.
Now I'm thinking of where to fit benches, lighting, power sockets etc. hopefully, I'll get some time tomorrow to put some more of the ceiling cladding up and cut the timber for the main bench in front of the windows. I've enjoyed the building so far (apart from the roof felt) but really want to get the lathe out again, sharpen the tools and start turning again. however, before I can do that I have to make a barn door for my daughters bedroom and I have started to notice all the jobs that need to be done to complete the house extension. It's going to be a busy few weeks until Christmas
