Billy Flitch
The traditional way to lap a edge tool is across the palm of your hand and then slide the tool through the end grain of a piece of wood . I don't see where flat edges come into that.
Billy Flitch":1h4h9mt5 said:The traditional way to lap a edge tool is across the palm of your hand and then slide the tool through the end grain of a piece of wood . I don't see where flat edges come into that.
Not against it - just against the obsessive insistence that it is essential.Beau":2q7ypcbh said:Not sure why some are so against keeping a stone flat. With a waterstone it's a doddle and makes the rest of the sharpening process easy. I am not going to bash away at this one I have said my bit and it's a system that works for me. Each to there own I guess.
Beau
Beau":1nbc29mz said:Agreed but IMO keeping the backs of chisels and plane irons flat is very important and trying to do this on a dished stone is nigh on impossible. For instance trying to do paring cuts with a chisel with a convex back is a complete pain in the rear end.Jacob":1nbc29mz said:Modern sharpeners are beset with strange rituals, imaginary problems, fears and anxiety. It makes it easy to sell them stuff.
It's also due to jig use - they don't work if things aren't flat enough - hence the scary sharp system and all that nonsense about granite slabs, plate glass etc.D_W":1s5k225s said:......
Most of the need for flattening has to do with trying to come up with paint by numbers things so that beginners can have success. I was in the same boat, it certainly works to flatten stones. I hope to never do it again on anything other than newly acquired stones.
It's not that difficult. If it was necessary, most of the old stones we find would be dead flat, and they rarely are. All you need is one edge of the stone to work past to keep from bellying tools.
Strangely, working over the edge of a stone will bring the stone back closer to flatness, and is what you do to avoid having a stone go out of flat in the first place (at least appreciably so).
The reason we don't do it all the time with oilstones (flatten them) is because it makes them cut more coarsely, and that's not very desirable. It also creates an unnecessary mess.
Hi David
I cannot agree with you here.
While the method you mention may (or not work) with oilstones, it would do so extremely slowly. I suspect that most just put up with out-of-flat oilstones as it is so bloody hard to flatten, and since you can sharpen a bevel on a curved surface. I would argue that "good enough" is no longer optimal in our changing world. The blade backs would largely be left as is or, at best, the rear 1/2" - 1" could be honed on such a stone. This would explain so many vintage blades with untouched backs.
The fact is that the practice of curved sharpening surfaces has never been part of Japanese woodworking. Waterstones are easy to keep flat, and this is one of the reasons why they are the medium of choice for many inside and outside Japan. One does not find Toshia Odate ridiculing anyone who flattens his waterstones and saying that this is unnecessary.
Regards from Perth
Derek
David
The problem with being adamant about what suits you as a recommendation for others is that it may not suit others. There is nothing inherently wrong with anything you stated, except that I cannot see many wanting to go along. For example ...
I keep my waterstones as flat as possible by using the surface as evenly as I can. I am clearly shocking at this since I still need a diamond stone.
I have a couple of sets of sharpening stones. One set is for demos at wood shows. These stones are tiny, but I have no difficulty working with them. They are similar to using the end of an oilstone, as you describe. Still, I much prefer using the full length of a flat stone since this is more efficient and reliable, especially when it comes to working the back. Yes, only 1/2" of the back needs to be worked, but it is actually easier to register more than this.
Using one stone? I guess so. I use a strop at times to refresh a blade. I stop sharpening after a Medium and Ultra Fine Spyderco, and that is up to, what, 6000, perhaps 8000 grit (- my impression ... Syderco say much less)? That is sharp enough for most work. However I was carving Fiddleback Jarrah today, and the best of this was not good enough to cut without forcing the blade into the wood (not a good idea).
Regards from Perth
Derek
