custard
CStanford":3u8lgss2 said:Garrett Hack on scratch stocks -- worth a watch --
http://www.finewoodworking.com/2008/07/ ... atch-stock
+1
Like most woodworkers I've ended up with quite a few different scratch stocks,
But the ones I use for virtually all straight moulding work, are the same style that CStanford linked to. Most UK makers I've met who use them tend to build them a little larger than the ones in the video, but it's the same principle. They're easy to make up using everyday jig making hardware
You just have to be careful to match the kerf slot to the actual thickness of your cutter material, so you get a snug fit. The huge advantage of this style of scratch stock over the traditional "L" shaped design is that you can tip the scratch stock forward to accommodate some grain directions...
...but then tip the scratch stock back the other way to gain a sweeter cut if the grain switches direction.
If there's a downside to this style of scratch stock (besides the obvious fact that it's no good for curved work) it's that there's no built in depth stop.
But in practise that's easy to deal with, you just put a pencil line where the apex of the bead (or other moulding) will be,
And when the pencil line disappears, you're done,
My personal favourite tool for bead work in figured stock is a traditional wooden beading plane with a 55 degree pitch, that gives a burnished result that's 100% finish ready. But this style of scratch stock runs it a very close second; plus it costs virtually nothing, the range of cutters is almost infinite, and in my experience you're pretty much guaranteed tear out free results,
