Fallacy, ever tried to get a biscuit joint apart once set, normally pulls the timber apart, also try shearing a biscuit.Kinda different though. I think I’m right that biscuits are just for alignments and add no strength, whereas Dominos do both?
I’m not sure either of those things prove joint strength do they? I’d have trouble pulling a glued joint apart (with decent glue) and can absolutely snap a biscuit if bending from the short ends. Snapping it across the length is more to do with the lack of leverage I would think (forgetting the fact that in a joint it would be swollen and hardened with glue so it’s doubly a moot point)Fallacy, ever tried to get a biscuit joint apart once set, normally pulls the timber apart, also try shearing a biscuit.
Glad you like it. It's funny though isn't it that as far as I can tell, part of what makes it good (and makes all the 'nearly but not quite a Domino' Aliexpress machines be left wanting) are relatively simple touches like the pins to allow for quick referencing off an edge (which Peters jig incidentally does have). Its not mechanically complex or expensive to design in, but most of the competitors don't have themI got a df500 and the sustainer with dominos/cutters a while ago. My day job is a joiner but the domino is mainly used at home for hobby woodwork. Its definitely expensive but I’ve not regretted it one bit and can say with 99% certainty I won’t be selling It, And that’s from someone who has no qualms about selling/replacing things.
I’m not rolling in cash by any means but what made the decision easier for me is I’ve spent way, way more on bikes and photography stuff (some of the photo stuff I instantly regretted). The no quibble 30 day return really helped. After 5 minutes, I knew I wasn’t returning.
What is really needed is a hole that can accept a rod, something along the lines of how a router fence is attached which would be far more beneficial in alignment especially if you had something like these but again with the hole to fit on the rod.are relatively simple touches like the pins to allow for quick referencing off an edge
The force required will be a shearing action so for assembling narrow boards to make a larger one as for a table then there is nothing wrong with a biscuit, once glued and clamped then once set it is not going anywhere. It all comes down to the right joint for the application rather than one method does all.Once glued into a joint the any bending angle will normally be very limited. To break the biscuit then relies upon sufficient tension being applied to tear the biscuit.
That is because most Domino fans do not use reality to test biscuits, when would a biscuit in place have a snapping action on the short edge as your test, my original post was about shear not a bending moment, I will agree that the Domino is a far better joint, but my point is biscuits have an equally if not more frequently used place in woodworking.In other news, it is very funny that this thread reflects so many I have read on other forums when researching biscuits and other forms of connector. Any time anyone mentions a Domino it's civil for a bit then eventually ends up in a bit of a disagreement about dowels, biscuits or pocket-holes.
Completely agree with everything you've said. I didn't test anything, someone asked 'have you tried snapping one' I reported back that you can, with the caveat that it wasn't along the line you are usually applying force. I'm no Domino fan as such, all I'm saying is that from all things I've seen that are vaguely a test, Dominos add strength (as well as helping with alignment) , biscuits don't. That's not saying biscuits don't have a place.That is because most Domino fans do not use reality to test biscuits, when would a biscuit in place have a snapping action on the short edge as your test, my original post was about shear not a bending moment, I will agree that the Domino is a far better joint, but my point is biscuits have an equally if not more frequently used place in woodworking.
Surprising what you can prove if you have an agenda.I've been surprised that online tests don't seem to agree.)
The biscuit has been around a long time, in the right joint then I think it is better than a domino or dowel. For joining edge to edge then it gives the alignment and I would have thought the strength was in the glue joint once cured.I will agree that the Domino is a far better joint, but my point is biscuits have an equally if not more frequently used place in woodworking.
Ah damn it! Have I been conned by shills for Big Domino?Surprising what you can prove if you have an agenda.![]()
Shopfitting have been using biscuit jointers for decades before festool released their loose tenon machine. Lamello was the kit to have and that was the pinnacle of the spec at the time, and not cheap. Currently their top tool is £1300I’m not sure either of those things prove joint strength do they? I’d have trouble pulling a glued joint apart (with decent glue) and can absolutely snap a biscuit if bending from the short ends. Snapping it across the length is more to do with the lack of leverage I would think (forgetting the fact that in a joint it would be swollen and hardened with glue so it’s doubly a moot point)
All tests I’ve seen online show biscuits to add no strength at all. If you’ve done tests yourself or can point me to any that would say otherwise I’d be delighted.
