AndyT":37qi2yzx said:
Just a thought - maybe we are looking at the wrong trade? I think I've read that handy little scrapers like this were used in trades other than chairmaking. Maybe it was aimed at gunsmiths - or made by a gunsmith for himself in a shop which had casting facilities? Or a coachmaker?
Nice find though. Any provenance clues from where you bought it?
Indeed - Alf's site shows a similar tool, called a gunstockers scraper. These are quite well known (Mr Lamond appears to have hundreds).
But the design is different to the chair devil (although it has similarities). At one stage I became VERY convinced this was a gunsmith's too, made by a gunsmith. If anyone can make a perfectly finished item from stock metal, using a forge, hacksaw and files, it is (of course) a gunsmith.
But the choice of material doesn't fit this. There's no cast iron in a 12 bore.
One final observation; careful inspection of the tool reveals that the inner faces (normally hidden) were made by draw filing. In a one off tool, I would expect the maker to spend the neccessary 2 minutes to make these surfaces as good as the outer faces. It doesn't take long to SiC a tiny area.
I have also cleaned up the wood a little, using 0000 wire wool to remove the crud.
Identifying small pieces of timber is very hard, especially when they're old and dirty. However, I am confident of some timber's that they're NOT.
They're not:
* box
* rosewood (any of the dalbergiae), kingwood, black wood etc.
* lignum vitae
I
think it's a mahogany, which again is an odd choice. if this (rather elaborate) tool were a one off, with all the effort implied by that, I would expect the maker to scrounge up a scrap of offcut of "fancy" timber to finish it off. The wood scales are so small that there's no real cost involved.
So, putting all this together (highly evolved design, cast iron, unfinished inner surfaces), I believe it to be a tool, made in moderate numbers (say 10-100) by a tool making company. I am not fully sure of the purpose of the tool; by far the closest tool is the gun stocker's scraper, but these were of a slightly different design, and always had upturned (gull wing) handles to allow their use on flat-ish surfaces.
BugBear
