We had a 30 yr old Eucalytpus tree in the garden last year which was getting too big ...so had it felled and logged.
Chopped all of it to firewood logs except for 4 logs of about 6ft by 1ft.
I've read many of the eucalyptus threads on here but wondered in anyone has any suggestions..
1. The large logs lying on the ground have split in many places mostly from one end right to the other and in some cases right through to the pith.
2. The small logs chopped up for the woodshed won't burn in our logburner ...even though they are dry to the touch all the way through (when you split them open) and even when the fire is roaring with beechwood and pine seasoned logs....the eucalytus just goes black a bit and splits.
3. It turns really nicely ...lovely streamers coming off it, but even being incredibily careful I cant make a good small tea light holder without a stringy bit (typically 1/2-1" long and 1/16-1/32 wide) deciding to leap out of the wood for no reason ... once even when just planing down the cylinder by a whisker with a skew.
4. There's not much in the way of figure and liberon finishing oil makes the end grain go a muddy colour.
5. If it wasn't for the tiny stringy bits that just fall out scattered throughout the wood it comes to a lovely smooth finish and might be nice for painting!
Has anyone got any good ideas for what to do with eucalyptus (given that I can't get my log burner hot enough to burn it!) or good experiences with turning it ?
I read about soaking it in water and then trying turning it, in the hope that the stringy grain would stay together better ...but cant see why this would work ...has anyone tried that ?
Anyways ... any ideas or positive experiences would be welcome ..
cheers
Keith
cheers
Keith
