Whippywhappy
Hi
I’m building an ‘escape from the mrs shed’
It’s 6m wide by 4m deep. Front internal wall is going to stand 2.6m high sloping off to 2.4m at the rear.
I started off by digging holes at every 1m, put 4”x4” tanilized posts into them and then used 4”x2” pefc timber for my supporting joists.
External walls are 4”x2” tanilized timber spaced at 600 to centre.
I’m using p5 t&g 22mm for the floor.
I’m going to be using 6”x2” pefc timber for my sloping roof.
This is where I’m a bit stuck:
Will I need to notch the timbers to sit on top of my walls? Or cut them so they’re flat on the walls?
Any advice would be gratefully appreciated
