Hemsby
Hi,
Need some advice for a small electrical job in my Kitchen, I will not be doing the work myself but wonder If what I think could be done, can be done, not to save money but to minimise disruption .
I installed the Kitchen 2 years ago including a built in oven & hob, (alongside a total bungalow professional rewire) now we are fitting a Range cooker (twice the width) the result being the Cooker isolating switch above the new cooker #-o .
Rather than chasing the wall down from ceiling with a new feed & switch to the side of the range cooker can I ask the sparks to chase across from the existing feed & switch about 300mm to a new switch connecting the wires with a short length of 6mm cable and a terminal block in the old switch then blanking it off, will this comply with regs :?:
Hope this makes sense.
