Tony M":f6ctpltw said:....Chas,
not sure what you mean by the capacitor housing... the cylindrical stuck on the end perhaps?
Tony
Tony M":3tyjxos0 said:Bob,
fear not, i'm not about to do that. I'm well aware of the dangers of doing that. That last post was just thinking out loud.
Chas,
Tony
The domed cover, abut 5" long immediately above the connector block position.
Possibly held on by just two small screws by the look of it.
You have not read and followed my part one guide have you!!
The capacitor housing is discussed there.
http://homepage.ntlworld.com/bob.minchi ... aft0.1.pdf
Bob
3. Induction motors that run on AC only and may be run single phase or three phase power source that are rated between 250 Watts and several thousand Watts or kW for short.
RobertMP":iw3dm6lo said:this does not read as well as it should -
maybe
3. Induction motors that run on AC only. Single phase design or three phase supply design and rated between 250 Watts and several thousand Watts (or kW for short).
Thought there was something else too but can't find it now![]()
Tony M":1v954noo said:Following on from yesterday, i had another look at my bandsaw motor last night and Bob was right, there was another wire lurking behind the metal case, as you can see...[/url][/img].![]()
So is it safe to assume that the two wires connect to the unused terminals in no particular arrangement - seeing as both wires are yellow and with no distinguishing marks- and the machine is then ready to go.
Tony
