wobblycogs
The formula E=mc^2 would probably not hold if neutrinos travel FTL. I don't know there theory in enough depth to say for sure but if neutrinos travel FTL you would probably see a larger mass loss that expected (assuming you could do sufficiently accurate experiments) as the neutrinos would require more energy when leaving. The formula would probably become something like: E = mc^2 + nx^2 where m is the mass of regular mass, c is the speed of light, n is the mass of the neutrinos and x is the speed of the neutrinos.
As I said at the beginning: this is going to be a systematic error in the way they are recording the result that is leading to a 60ns difference from theory. What is interesting is that these people are professional scientists and they have a result that appears very valid at first glance. As a scientist I have to remain open to the possibility that they have discovered a real phenomenon but at the same time I rate it right up there with pots of gold at the end of rainbows and finding faeries at the end of the garden!
As for what did Einstein say, blimey what a question. His big work was special relativity (1905) which deals with how bodies move under special conditions (excluding gravity). He then followed this up with general relativity (1916) which takes special relativity and incorporates gravity - very clever. Both pieces of work discuss the speed of light at length and require it to be an upper limit.
Our current understanding makes the speed of light the hard upper limit for any item with mass due to the fact that it would require infinite energy to accelerate anything with mass to c. Going beyond c would therefore require more than infinite energy which doesn't make sense.
The pedant in me has to point out that by convention lower case c is reserved for the speed of light and lower case m for mass.
