The router is mounted in a table, and intermittently (say 1 in 3) will blow the fuse on start up. It is plugged straight into the NVR switch on the table which, in turn, is plugged straight into a wall socket.
It's only a 2200w motor, so I can't see where the problem is. When it doesn't blow a fuse, it runs fine.
It's beginning to bug me !
Any help or pointers appreciated.
Karl
Karl
