mindthatwhatouch":1bwqlshj said:......It’s one of those jobs that an extra pair of hands goes a long way, especially when it’s windy.
I did and I think that is the right way as the battens need to be attached to the roof structure.John Brown":1wiokebi said:Sorry for the dimb question, but dou you nail the battens on through the membrane?
MikeG.":o2j1za3r said:Just be careful that door isn't too heavy. It sounds a monster.
But will it need primed if I use cheap emulsion? If so what with?MikeG.":1zd8lcua said:Painting OSB (inside the building) can be done with the cheapest emulsion you can lay your hands on. There is absolutely no point using expensive paints such as Bedec or a masonry paint. Save Bedec for outside.
beech1948":3nw18hzi said:I can not see from your last picture but Onduline will sag between the roof members such that over 5 yrs you will have a 3" to 5" sag which collects and holds water. Onduline has no strength to resist this. Guess how I know this.
If still using Onduline then you need to provide either ply (1/2") or 3/4" OSB for the Onduline to sit on.
MikeG.":1qmyuwje said:Yeah, that's your best answer.
You seem to have plenty of battens in support, so sagging won't be an issue. However, I'll warn you now that your roof will be black, not green, within 5 or 7 years. I did a workshop of mine in green, like yours, and it was identical to the black stuff by the time I sold the house.
