sometimewoodworker
I haven’t talked about heat effecting glues, nobody has, it’s the cold that has been discussed. I am happy to try a little that has been subject to temperatures down to 4C for as long as needed. I don’t think a freezing test for PVA is useful as the general consensus is it’s not good for them (though I do keep my cyanoacrylate glue in the freezer and the opened lifespan is very long, years)It's a hot Country - you probably don't get the formulations that are adversely affected by heat.
that is what is claimed, however isopropanol is a constituent, the first listed on the MDS/SDS, and alcohol is a solvent so the claim is clearly economical of the truth.D4 contains no solvents and is water soluble. It does class it as a "hybrid resin" though, so isn't a normal PVA - PVAs are usually advertised as water resistant not waterproof. Brilliant stuff. 502 is fine as well, with a bit better open time.
I am saying nothing about its quality as a glue and since alcohol and water are miscible it certainly can be water soluble.
That point however is that as you say it isn't a normal PVA so the pot life and other characteristics are likely to be different, so how is it relevant to the question of the thread?
The qualities of different glues are certainly an interesting topic though not really in this thread, don’t you agree?
