gidon
Karl's post on back bevels has prompted to post my solution for applying DC's ruler trick with a plane blade without taking it out of the honing guide:
The guide simply pivots on the back of the honing guide and the small back bevel is dictated by the extension of the blade and the height of the polishing stone. You simply need a planed piece of timber to rest your polishing stone on - a rough measurement and small amount of trial and error will give you the correct thickness. The beauty is unlike with the ruler trick the back bevel angle will remain the same where ever you rub the back of the blade on the stone .
I know it's simple but always bugged me taking the blade out of the jig to apply the ruler trick.
Gidon
Gidon
