Another grand day today. I started off by getting the easy boards up in the roof, this comprisedof 2 whole sheets, 2 99% whole sheets and then 4 smaller cut peices. With those in place I could start the fiddly bit of cutting around the rest of the rafter ties/joists.
A handy resting place for an unwieldy sheet
"Easy" sheets complete
I was once again fortunate that the distance from the wall to the ridge was nigh on 2480mm, and I needed to leave a little gap to be able to swing boards up past the ridge as it sticks out below the rafters. So a 2440 sheet pretty much filled the gap entirely. The gap at the ridge will be covered with a single piece nailed to the underside of the ridge.
So with the offcuts of my earlier exertions I could begin measuring, marking, measuring again, writing on the wall, checking and finally cutting. All in all not too difficult, though true to the rest of the project I was unable to not copy Mike in one more way. For one cut, just one, I had measured the distance to the rafter, and not the joist. Ploppers.
Todays cockup
Todays result
With that all finished I could hop (more like teeter) onto the roof and nail on some supports for those cut ends, then come down again to finish the nailing inside.
Next up it was time to attack the insulation. I had 23 sheets of 610x2440 60mm insulation already up from the farm. While the stuff is easy enough to cut I do find that handsaws make an inordinate mess. Add to that an element of drunken blade wander and I figured since the table saw was still out it was the work of a moment to rip all the sheets down to size, and lo, it was. A nice finish on the edge too so less bits flapping around.
This is the insulation that cost £120 for 60 sheets, so thats 30 full sheets, equalling just £4 for a full sheet. The joy of farmers sales. The second batch did test the wallet a bit though at...£6 per full sheet.
Again, these were not bought for this job, they were bought for use around the farm (cottages, houses etc) over a year ago.
So off I started carving them up to work around bolts and joists and so on. Once you have a pattern for the first one the next become much easier. I ended the day doing the nice easy sheets in the vaulted section with no pesky bits to cut out. Just trim an angle off the end of the first piece and in they sailed.
I'll have more insulation and expandy foam brought up tomorrow morning while I'm sorting the remaining sheets out. Hopefully I can get them all done, foamed and membraned before the expected thunderstorms on Friday morning. It would be nice to get the walls done too, but its just not going to happen. I'm a little less worried about those.
flying haggis":129711lh said:
dont know about making your own shade, more like making your own sauna.
keep up the fluid intake :wink:
Yes it was a little hot boxy by the end of the day! Did feel a little less burny than yesterday despite high temps today though.
