YorkshireDave
tisdai":1r7w3l6b said:
+1
Have I got this right. Would I be able to create a standalone cyclone from this kit with external clean air filters
Eric The Viking":v6um4x21 said:Putting strips of 2" aluminium tape carefully on the surface inside, possibly just at the top (no wrinkles/bubbles), and earthing through, say, a 50k resistor. That will probably kill the charge, but still allow for smooth air movement.
DaveyP":2g950mm3 said:Hi Eric
Why do you feel a 'discharge' resistor is required ?
If the cylinder / container is conductive, then its conductive and a single earthing point should do.
I think for current-limiting reasons.
Chems":160sw1mi said:Not to break up the static discussion, I need some extra market research.
I was planning on including the super glue with the kits, but I figure most if not all of you must have super glue already, so if I leave it out and offer it as a extra it will keep the overall cost down some more. Any super glue will do, just not the 2 part mitre fast stuff, it works fine but when it goes off it releases a gas that stains the lovely clear plastic around it.
Thoughts?
paultnl":31r9n8gl said:Chems":31r9n8gl said:Not to break up the static discussion, I need some extra market research.
Thoughts?
No problem leaving ot the super glue, that is something we all have or can source from the pound shop. It might be beter to include the grounding strips as I am sure we don't want to order a role just to get a short bit for this project.
