That is logical and how I did it,I started in one corner and worked my way to the opposite corner.
Thanks for all the responses guys. I just received my bench dogs gear yesterday, I think I'd better play with standard size MFT for a month or so before figuring out my custom size. Essentially I think the standard depth (718mm) is fine, I just want the 1400mm to allow a little more room to play.
Not sure if I should start another thread here but I'm having trouble setting the bench dogs gear up. I bought the rail square which seems to be spot on, no issues there. It's the fenceM2/rail dogs set up that is foxing me. I assumed there is no calibration necessary but my cuts are way off. Any tips for this set up? I figured the fence/fencedogs coupled with rail dogs/b collars would just slot it, tighten up and be square to the holes?
Confused and a bit disappointed, I then put the old Festool MFT rail back on, moved the factory stops and squared that up (I copied Peters method from his video about changing his old top). I used a very accurate Woodpeckers straight edge up against X2 dogs. Used my feeler gauges, all good. The cuts are off in exactly the same way! All I can assume is that the holes in the table are not accurate as both methods rely on them.
Any tips? If the holes are the issue then I could get a new top but I've already spent £350 + on bench dogsUK stuff so thought it worth asking before spending even more cash. The UJK Valchromat top claims to have 'perfectly aligned holes' but who knows if that's true. Or I could buy the Part MII for not much more. God only knows what's more accurate. You'd assume CNC but I guess it depends on who's doing it. Plus I don't even know if the holes are the problem!
Any tips would be greatly appreciated, I don't want to be regretting this purchaseDom
It seems more intuitive to start at one corner and work across. That was half my problem with the MKI system! If you are really careful I am sure this can be as accurate. I can see why starting in the middle is a better way and it certainly worked for me. At the end of the day, however you do this it is the care and attention of the user that determines the result. I found the holes were a really tight fit and used the UKJ hole reamer which produced perfect (for me) dimensioned holes.I had excellent results from the UJK Parf MK II Guide System on my 2x1 meter worktop with 200 holes. Had I followed the instructions, I would have started from the center, worked to the edges, and trimmed the edges to match the grid pattern of the holes. Instead, I started in one corner and worked my way to the opposite corner.
I still trimmed the long edges of the Valchromat top using the track saw, but the alignment of the holes were perfect (in my opinion) for any woodworking projects I will be doing. I spot checked the top in ten places using my TSO MTR-18 square and four UJK Bench Dogs, and there were no gaps between the square and dogs. I also checked the alignment of holes along the 2-meter length using the 3-meter track saw guide, and I couldn't put a 0.03mm feeler gauge between the track saw edge and bench dogs along the side.
Maybe I was lucky, but I think my results are due to being patient and not rushing the drilling of the pilot holes or the 20mm holes. I never clamped the 20mm drill guide because I didn't have to. As soon as it was located and fixed in place, it did not shift or tilt.
I wish the 1-meter long Parf sticks had V-grooves in the ends with the apex of the groove along the center line of the 6mm holes for the pilot bushing. This would make it much easier, at least for me, to align the sticks along a reference line instead of relying on the line perfectly bisecting the 6mm hole.
Option: Buy two 'standard' CNC design tops, cut second to suit?Thanks for all the responses guys. I just received my bench dogs gear yesterday, I think I'd better play with standard size MFT for a month or so before figuring out my custom size. Essentially I think the standard depth (718mm) is fine, I just want the 1400mm to allow a little more room to play.
Been looking at @ian33a 's bench design again along with several others and it is different from many others in that it is modular and is not tying you down to a system. By this I mean you can have the 20mm holes but you can equally swap out the inserts for no holes, holes and micro jig slots or a router insert in one and then use the Incra positioner and Benchdogs locating plate in the other, it is something I am looking at for my next modular bench design to free up floor space by illiminating the Kreg router table. It also has very clean lines for a workbench, it is like a piece of furniture so well done, I like it.
The one thing I may do different is to have a front apron that is hinged or removable with 20mm holes and microjig slots like Denis from Hooked on wood has done which allows you to work round corners and hold work side on upright.
Maybe not the right place to ask but are people using this style of bench instead of the more traditional workbench or as an extra? I made mine because I wanted something that I could use at my workshop (rented) & my home. I already had a centipede pop up frame so built a top to fit that, having a CNC makes things like that a lot easier lol
