Convert old fridge for paint storage etc.
duke
27 Mar 2021
Field, Ontario, Canada
Tired of hauling paint to the house in winter. Figure I could mount an incandescent bulb or a low watt heat lamp. Fridge is in garage 10 steps from the shop. Anyone done this, any thoughts?
Put two similar power lamps in series. Each will produce 25% of it’s rated power but they will last forever.
I used to use that technique to keep a tool cupboard free from rust.
Installed a fixture attached to ceiling of the fridge. Using a flood light at present, measured the temp. before turning the lamp on. Will check temp. in an hour.
I would add some ventilation too.
Gives a chance for any moisture build up to escape rather than cause mold and fester.
Have you had paint freeze before? What does it do to the paint in the longterm?
I guess it depends on the type of paint.
In my limited experience with household paint (gloss/emulsion) it either separates and never recombines no matter how much it’s stirred or it doesn’t dry properly and stays tacky.
