phil.p":88lkcy5r said:He did at least attempt an answer.I retired defeated.
If it's clarity and brevity and a tangible conclusion that you want, you'll never get it
No skills":2a49juk3 said:I have a bar of green possibly non-descript polishing compound being delivered this week - a first for me but boring humdrum for others.
profchris":3em5j8bu said:Hmm. If it's not removing metal then it's doing something very clever indeed, probably at the atomic or subatomic level by rearranging the atoms of the blade without removing them. I think a Physics Nobel prize is in the works!
Biliphuster":11itsi48 said:profchris":11itsi48 said:Hmm. If it's not removing metal then it's doing something very clever indeed, probably at the atomic or subatomic level by rearranging the atoms of the blade without removing them. I think a Physics Nobel prize is in the works!
Some polishing compounds work by chemical action, for example Cerium oxide is commonly used to polish glass and works by partially dissolving the surface of the glass which will smooth out ridges and bumps.. Colloidal silica is another common polishing media that works at least partly chemically.
I agree the Chromium oxide is probably only acting as an abrasive but this is not true for all polishing compounds.
matthewwh":1281qzcd said:There are several factors involved in hand planing other than just having a sharp iron, on reversing grain a steep effective pitch, achieved by whatever means, is at least as significant a factor as edge condition. This makes it a poor example of a situation where sharpness itself is critical.
Paring endgrain with a chisel is the traditional example of a situation where a sharper edge is desirable, indeed the ability to pare softwood endgrain cleanly without separating the fibres is often used as an imperfect measure or means of comparing sharpness.
woodpig":3kg9tyg5 said:I doubt there are any products made specifically for honing. More likely they are just polishing compounds.
https://www.menzerna.com/products/solid ... steel/333/
http://www.thepolishingshop.co.uk/acata ... ar-p1.html
matthewwh":23mb3ng8 said:Stropping on the palm of your hand works if you don't have anything else, but it's can come at a price. I now have an irritating persistent lump of hard skin on my left hand that I believe is caused by a deeply embedded metal splinter from doing just that. It's hardly life threatening but I wouldn't recommend it.
