Phil Pascoe
So it's different. How?
phil.p":k5xskjwd said:Just out of curiosity, Stewie - why the British leather for the strops? Is it significantly different or better than Australian?
swagman":1v6uzqnn said:Its the cut from the kangaroo tail that's prized as a stropping leather.
phil.p":3ji0ficb said:Kangaroo steak is rather good.
Or you could just buy a tube of fine metal polish, or any equivalent of T-Cut and be done with it :mrgreen:
That's entirely up to you Stewie.swagman":12aiothe said:Or you could just buy a tube of fine metal polish, or any equivalent of T-Cut and be done with it :mrgreen:
Ed65; how do you want me to respond. !!!
Stewie;
Stewie, I presume from your recent threads that cost is not a major factor for you but for anyone else who'd have significant shipping to swallow on top of the purchase price FYI you can buy pigment-grade CrO from many artists' suppliers. Chromium oxide sold for artistic use is guaranteed to have a small, and usually very uniform, particle size. And it's in dry form so there are zero long-term storage problems, your great-grandchildren could use any remainder if it came to that.
As a single tub would be more than one person would need in a lifetime for stropping duties you can spread the cost of the purchase between a number of like-minded friends if you like. Each person can blend it with an oil or wax as they prefer, to make up a liquid, paste or solid block.
swagman":2z8zonah said:Ed65; how am I expected to respond, you obviously have the greater depth of knowledge on this topic.
Stewie;
The likelihood of rounding the edge by stropping depends upon what the strop is made of, and your technique. I use a MDF strop which is not prone to round the edge unless the user lifts up the blade towards the end of the stroke. I don't do that, but many may. No telling what different people might do.
I wear a 1 1/2" belt custom made of hard English harness leather(The harness maker made it for me. Probably will outlast me!) I take the end out of the keeper and use its HARD suede side as a strop when sitting in the living room. It brings back my SLIGHTLY less than razor sharp ball bearing steel blade pocket knife blade, which I made, to razor keen ness. I take light strokes, and may do 100 if needed. There is no compound on the belt. Certainly gets the knife razor sharp again. I get about 8" of belt to strop on when I pull it out of the leather keeper. Only use about 3" to strop on. I CHANGE ANGLES a lot. That includes the initial stropping after honing the blade on the last stone.
I find I don't need to strop after the UF ceramic stone. It will get razor sharp just off the stone, easily shaving hairs. But,part of that is how I USE the stone. Angles ,etc. .
I repeat: ITS ALL ABOUT TECHNIQUE that you bring to bear on the strop. Not necessarily the strop itself, provided the strop is made of good material itself, properly compounded (for initial stropping just after stoning),etc..
swagman":2f21qghh said:Another relevant detail to add; you have already stated previously you don't use the green wax honing compound on your own strop.
And yet, here you are condemning me, for also daring to use a different product. !!!!!
Stewie;
