mailee
I made a start on two new cabinets today and it's a new one for me as they are in Cherry. :shock: Again I used the Domino as the carcasses are in veneered board. Started the day by cutting out the pieces for each of the cabinets.
I then cut the rebate at the rear which will house the back panel. This will be in 18mm as it will be hung from a wall.
Next I attacked it with the Domino putting in the slots for the horizontal pieces.
There will be a small mirrored cabinet with glass shelves and this was given the same treatment with the addition of holes for the adjustable shelves.
With all the pieces cut I had a dry fit using some sanded Dominos to make sure I could remove them again.
There will be a painted door on the bottom of this unit so I cut some MDF to size for this.
Tomorrow I shall be lipping the edges of the panels with solid wood and adding the cornice and plinth. When this is complete I shall put a finish on the insides before assembling the unit.
I will as usual keep you posted. ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![](https://proxy.imagearchive.com/f91/f9173fd9b9ce542d66be374adf0f5c33.jpg)
![](https://proxy.imagearchive.com/5eb/5eb83ab5b21af5075eb9b33bc8707e13.jpg)
![](https://proxy.imagearchive.com/f43/f43b745991f3389175f1a01de0df7af3.jpg)
![](https://proxy.imagearchive.com/9f0/9f03962e49a92cd57054e4ae5e1221db.jpg)
![](https://proxy.imagearchive.com/26f/26fd33203d89747aee87282c8f595805.jpg)
![](https://proxy.imagearchive.com/5e6/5e6161bb3e7c341cb5daafb78327c511.jpg)
