RogerS
If you bleed a central heating system with the pump on you will draw more air in, see the link below
http://www.homeserve.com/help-advice/bo ... iator.aspx
Stew[/quote]
They are partly right. It depends on where the pump is fitted. If the pump is in the flow (where it should be) then it doesn't matter one whit. The system is under positive pressure and so no air can get in. But I'm guessing that they are covering themselves for the odd plumber who sticks the pump in the return.
The only other possible reason is if it is a major bleed and that there is going to be a lot of cold water going into the boiler and the boiler is hot then that 's not a good idea. Nothing at all to do with getting air into the system, though.[/quote]Roger
I have checked 10 different web sites and phoned 2 plumber friends (both are also Gas Safe) and all have said you must turn off the heating before you try to bleed your radiators, if you don't you will draw air into the system! I too thought tha same as you, but when given the advice of professionals I accepted they were right.
Stew[/quote]
LOL! Both you and I are correct. It's a bit like speaking to 100 electricians about supplementary bonding and finding that 99 get it wrong.
Ask any of them why. I bet that none of them will give an explanation. Ask them how is air going to get into the system when (assuming the pump is on the flow) the system is under positive pressure. I will donate £20 to a charity of your choice if any of them come up with a proper, sane, rational answer! :lol:
Stew[/quote]
Stew[/quote]
