Adam W.
A Major Clanger
He may already be amongst us..................spooky.
Good Lord, stropping has always been about tipping the blade or chisel up at a higher angle that the one at which it was honed. And hitting both sides. With the fine media available today, stropping is completely optional and any noticeable improvement is as likely some weird woodworking equivalent of the placebo effect in medicine, than anything else. "Here, take this pill (it's nothing but sugar) and you'll feel better in 36 hours." 36 hours later: "Doc, I feel great!" Doctor: "I knew you would..."Just to be clear, the Unicorn Method (yes, horrible name) is not about stropping, per se. It is about creating a high angle edge. And this edge must be extremely tiny - nano tiny - so as not to interfere with the blades entry into wood. In other words, it is not a scraper-like action. The angle at which one holds the bevel to the wheel is different (much higher) than when stropping at a wheel in the traditional manner. If you do not know this, then you are not comparing apples with apples.
Earlier, Jacob linked to my article on it. In this I discussed “preparing” (I’d rather call it that than “sharpening”) chisels. Beforehand, these chisels could not cut as well as a banana. The Unicorn raised the bevel angle and helped it improve edge durability, and without impacting on the cutting action.
Do I use it? No. The Unicorn was designed for crappy steel, and my blades do not need it. Further, I prefer to hone on a hollow grind, which is predictable, and the Unicorn is not a predictable result for re-sharpening. “Re-sharpening” is probably more important than sharpening once.
Regards from Perth
Derek
That forum is beyond dead. The only thing keeping it going is the guy that started it won't pull the plug and let it die a dignified death. Flights of fancy into tool steels, the cap iron, and similar garbage to the exclusion of all else just killed it. A cautionary tale for the mods here.Edited today!
Is this a D_W comeback performance?
No, it's a date generated by the software running the forum. The old html file was read into the database and that's the timestamp you're seeing.Edited today!
Certainly is! Or merely not perfectly flat face on chisel or plane blade.When pressed on the details, whys and wherefores, the "Ruler Trick" became a workaround for pitted steel.
My most pitted plane blade is a very old laminated Stanley but it sharpens beautifully with the aid of the "without a ruler" trick. It's the same as the ruler trick but easier and quicker. Unicorn free too.Now, when pressed on the details, the "Unicorn Method" is said to be for inferior steel.
I'm noticing a trend.
It's for the crowd who prefers pitted, inferior steel.
Got it.
If you hadn't had $25 to spare you would have made it work perfectly without giving it a thought!I had one square-top Record iron that was pretty badly pitted. I just found a replacement on EBay with no trouble. That's my entire experience with pitted steel, or at least that I have a specific memory of. To make others feel better -- I just slapped myself on the wrist for spending $25 instead of working around the pitting using some silly trick. Consider me properly scolded.
Probably a lot of elbow grease and if that didn't work the old 'tilt up.'If you hadn't had $25 to spare you would have made it work perfectly without giving it a thought!
