Paul Chapman
Pete W":1380cyqp said:Did you make the stone holders? Are they a box-like construction, or hollowed from a solid piece? Do the stones simply sit in the hollow, or is there a holding mechanism of some kind?
Thanks for any info.
The two light colour boxes came with the stones but I made the dark one (the stone was less expensive buying it without a box). They are all made the same way - solid wood hollowed out with a router. They have lids made the same way. The stones just sit in the hollowed out piece but they are a good fit. I varnished them with polyurethane varnish (I think I used the Liberon one) which has made them resistant to oil - there's usually a small amount of oil sitting in the bottom of the boxes and it hasn't soaked past the varnish yet.
The DMT boxes have four small rubber feet which stop them sliding about but I didn't bother with them on the one I made - if you look at the picture you will see that I have a piece of wood screwed to some chipboard which the boxes press against, so they don't move about.
I need to do a re-design of the box with the extra-fine stone. I now use a Veritas Mk2 honing guide and have to take the stone out of the box when wiping the wire edge off the blade with the blade still in the guide - still thinking how best to do that, or maybe I won't bother :-k
Cheers :wink:
Paul
