Noho12C":37uxcn92 said:
Out of curiosity, what oil do you use ? Is 3 in 1 the same as wd40 (the latter seems the primary choice in US)
I'm not sure what the chemical formulation of WD40 is, but I'm pretty sure it's not the same as 3-in-1. It seems a much lighter oil, nearer to petrol or diesel than light lubricating oil. There's no reason to think it won't work to lubricate oilstones, though, especially the impermeable natural ones. Not so sure about man-made ones; I think it might be a bit thin for them. It may just soak straight in.
I used to use 3-in-1, but following a tip on this forum (thank you, whoever gave it!) I tried a bottle of baby oil, which the label told me was paraffinum liquidum. Turns out this is highly refined mineral oil, suitable for dermatological use (which WD40 might not be). When that container expired, I hunted online for 'mineral oil', and found a supplier of massage products* ( :shock: ) on Amazon selling 5 litres of mineral oil for about £25 delivered. That quantity should see me right for quite a few years.
The India stone can slurp up a bit of oil, and also tends to do most of the sharpening work (the natural Arks would be a bit more frugal, being impermeable). My polishing stone (an Inigo Jones slate hone) barely uses any at all. I find that the slate just needs a wipe at the end of a workshop day, but the India needs lifting, wiping all over, and mopping up of the oil that's seeped through and leaked out of it's bottom.
The purpose of the oil is to float off the abraded metal particles rather than lubricate. When a stone is cutting well, you can see the oil turning black with cuttings and carbon from the steel. Pretty well any light oil will do, and there are all sorts of home-brew concoctions recommended down the years, depending on what happens to be near to hand. Paraffin, lamp oil, diesel (don't really recommend that one!), engine oil and white spirit mix (not sure about that one, either).
The old boys of the 19th century used to use neatsfoot oil (still available from saddlers and agricultural suppliers, I gather) or 'sweet oil' (think that's olive oil) on their impermeable natural stones, but the latter is probably best avoided on porous man-made stones, as it can sink in and go rancid. Let's face it - nobody wants rancid stones. Avoid using drying oils such as linseed; the result will be a hard, brown crust if left for a week or so.
* They were called 'Mystic Moments'. That should add a new dimension to the sharpening experience!
