matt":3t71aw2r said:Out of interest, why did you have the blade protruding so high for a 6mm thick cut?
Another fault of the guard and riving knife set-up. If you have the blade protruding 10mm, the riving knife is below the level of the table. So you have to increase the blade height to get the riving knife above the table. Then keep increasing until you can attach the guard. Then keep increasing until the 6mm piece passes under the guard.
In summary, the knife/guard system is a pile of cr@p.
Mike.C":3t71aw2r said:Karl did you keep the (£30 bargain) Axminster extended arm and crown guard that Rob mention's?
No - I sold it on to Trim The King. It's too big for my 'shop. Hence the reason that I need to make a better guarding system.
jasonB":3t71aw2r said:In your case any pressure on the front of the guard or vibration will make it pivot on the nut/bolt and make the rear fixing lift until it comes out of the open slot.
It's probably been covered before but how do they get away without CE marking?
I think that vibration has caused the guard to work loose and fall forward onto the blade.
No idea on the CE system. My understanding is that you can use a non-CE machine in a personal capacity but not in a commercial environment. But not sure why a manufacturer would release a machine onto the market which isn't CE certified.
BradNaylor":3t71aw2r said:I'd be having a quiet word with Mr Arrowsmith if I was you, Karl.
His policy of ignoring CE rules is going to bite him on the ass one day
I reckon he'd laugh his cock off and rattle on about "amateurs".
If i'd bought the machine off him from new then it'd be a different matter. But I don't think he'd give a rats ar$e, seeing as I didn't buy it off him.
