novocaine
much better.
2 thickness of 270gram card stock or 1 business card.
Thanks Nev. The plug connects to the holder using a screw thread - will they all have that, and is there likely to be a metric/ imperial problem, or are all threads the same? And when it says alternatives, does that mean any of those would work ok?nev":73t89aqo said:(Champion) 8com is indeed the plug number and a tad unusual, check here for a list of alternatives
http://www.gsparkplug.com/1x-champion-s ... gotoupsell
I really wanted to try spinning the flywheel but couldn't figure how to connect a socket to the drill! We tried a bit of wood held by a screw and driven by a screwdriver attachment but the screw thread tore through the wood after a couple of turns. WHat would be a better way of connecting them?novocaine":73t89aqo said:I don't think there will be much wrong with the plug, I think it's more likely a lack of magnetism in the flywheel from sitting for so long and various dirty contacts in the LT side.
Chris152":13zxguzo said:Thanks Nev. The plug connects to the holder using a screw thread - will they all have that, and is there likely to be a metric/ imperial problem, or are all threads the same? And when it says alternatives, does that mean any of those would work ok?
Beau":1rt3snro said:Thats a much better way to spin up a Seagull. Remember my dad nearly knocking my mums teeth out with a the old rope starter![]()
Thanks Bob. I got confused about the plugs, which isn't surprising - so called Classic Seagulls to be sure I was getting the right thing, which is this:sunnybob":1iasb2sv said:There should not be different lengths of spark plug with the same number, that negates having numbers. measure the length of the thread to make sure you get the right one.
DO NOT yank the plug lead off unless you are wearing insulated gloves or have a lump of dry rag, and even then not if you have a pacemaker. having stopped several engines this way in the dim and distant past, 20,000 volts up your arm is a feeling that stays with you forever.
I dont know this particular engine, but magneto units usually have an earth wire connected to the bolt in the centre of the points cover, which "should" lead to a flip switch and then onto earth (ground) to kill the circuit.
apart from head gaskets, which are normally copper / paper laminates, any other gasket will be thick paper, which can nowadays be replaced with a silicone gasket goo.
I'd seen they have a workshop manual on Seagulls, reckon it's worth getting - the boy tends to do everything by phone which works ok most of the time, but it's not the same as having it there on paper, making your own notes and that. Well, that's what I reckon. Cheers.Doingupthehouse":1iasb2sv said:Hi,
You may already be aware of this, but Sheridan Marine stock most spare parts and workshop manuals for British Seagull motors.
https://www.sheridanmarine.com/category/british-seagull-outboard-spares
Simon.
