Pete Maddex":2g51mjz3 said:MMUK":2g51mjz3 said:Jacob":2g51mjz3 said:Heat treating/tempering can be DIY
You have a furnace capable of 1200 degrees then? And an oil quenching bath? And another furnace at about 220 degrees? And a water quenching bath?
You obviously haven't got a clue about the proper heat treating and tempering process :roll:
It is possible in a barbecue with a hair-dryer to get up to temperature and an oven can be used to temper, for small blades a MAPP torch works.
Yes, easily done in the garden with some charcoal. I used a heat gun for the blower. Ground flat stock is available in lots of sizes and you don't need to heat the whole blade. Full instructions for hardening and tempering are on the packet.
If heat treating is too daunting then just buy the steel and cut to shape then get someone else to heat treat.
