kingcod
- Joined
- 12 Nov 2008
- Messages
- 107
- Reaction score
- 1
My first forray into design and build so any comments and suggestions welcome.
I am embarking on a fitted wardrobe in the eaves of a loft bedroom hence the unusual shape.
I'm aiming to use 18mm oak veneered MDF with oak edge blocks blued and biscuited. Its likely to be without its own doors as its a walk in wardrobe
For the tops of each section I will also use biscuit joints. The shelf just on brackets (I hope it won'ts sag over the distance)
The plinth is simply oak veneer for the visible bits and then blocks along the load bearing bits. Fixed direct into the new loft flooring with one or two anchors through the plasterboard wall.
All going to be cut on a table saw or handheld circular saw if need be.
Am I on the right track here? Should I pre-assemble any of it or build in situ?
