Steve Maskery
Those guide bearing work in a different orientation to mine. A better one, in many respects. I can't really tell, but I would expect them to be eccentrically mounted, for adjustment.
OK, so sticking a piece of MDF on to the face isn't going to do the job, but those bearing look like they could be easily removed with an Allen key, so you could simply replace them with a circle of 6mm MDF. I'm sure there is an easy solution. Indeed. as they appear to front mounted ( from a screw point of view) you could replace them with any kind of wooden block to do the job. I think you have lots of viable options.
S
S
