KT_NorCal
The cant shaft is fully apart and I cleaned up the burrs from where the meathead at the factory tried to hammer the roll pin though the solid bar. The shaft itself doesn't seem to be bent... its not perfectly flat, but its close enough.
Cleaned up the burrs on the various stops as well. Interestingly the outer rear one and the one with the grub screw were both cold blued. I'll re-blue them as I think they look nice. The citric acid dip tends to ruin the bluing. Seems like an interesting thing for the factory to do. They had rust on them, but a lot less than the unblued one, so hey it helped a bit.
