woodbloke
TheTiddles":14mhinoy said:Looking forwards to seeing that Rich!
The thing I find interesting is that these solutions require you to reach past the saw to use the router, whereas going at it from the other side is easier but you would have to use the tablesaw fence and not the Incra. I'm liking the dual use of the Incra, might make it worth buying one, just how wobbly are they? For instance, would you use one for ripping a 2" thick beech plank in half or go with the saw fence?
Has anyone built a full length fence for the TS200 that clamps tot he rear rail also or at least extends further? The current one is very tough for what it is but I'd like one a bit longer that isn't just a piece of wood clamped to the existing fence. I suppose with the Incra fence you could ditch the front and back rails or use them to lock the Incra fence down for bigger jobs?
Aidan
If I'm reading this the way I think I'm reading it, the router fence is also used as full length fence for the saw? If so then that's a big 'nil points' for me...kickback! A short fence is far more desirable for a saw - Rob
