Axminster TS200 unit
Hey chaps, there was one last measurement I was hoping someone could help me with; what is the height of the actual base unit without the floor stand? Cheers.
I took delivery of my TS-200 today after using the 10% axminster discount, setting up was quite straight-forward, took about two hours, I still have some final squaring and checking to do, but otherwise it's functional.
This is the first part of the new layout. I'm removing the old out-feed table the SCMS is sitting on completely, and will move all the crap that is under-neath and the SCMS to a new full-width unit at the back end of the shop, this will have a shelf unit and a worktop running full-width and will house all the power-tool boxes and various crap that accumulates over the years.
The drill press will then move to the left-hand side of the shop along with a new rolling unit housing the thicknesser that I received today also (A perform CC10 which came with a discount, result!)
There's a bandsaw which sits just inside the front doors, and that wheels out if I need to do longer stock.
A router-table will be fitted in place of the crappy sheet-metal extension table on the TS-200 (will probably just use laminated MDF and tilgear plate).
All in all, I feel confident that this should be a decent and long-term setup.
Piccies:
The piece of ply under the TS-200 is used to raise it to the same level of my workbench so I can use it as an out-feed.
Thanks again to everyone who answered my questions about this saw, and for letting me hijack the thread a little. I'll post more pics when the saw is integrated into a rolling cabinet with router-table.
That does look good, Byron. It will be interesting to see whether it's still as spacious twelve-months from now though! :wink: Don't forget to clear your workbench before using the saw - otherwise, your timber and sheet materials will do it for you!! :D
I assume you're trying to get by with nothing but the bare necessities - ie. no bobbin sander or spindle moulder? I like how you can access your bench from both sides.
It should be more spacious in a few weeks when I clear out some un-needed fixtures (gardening stuff, old out-feed table etc..) Good point about leaving stuff on the workbench, I usually put tool away as soon as I've finished with them out of habit, so hopefully, I won't knock anything off! :)
Moving that bench there was inspired by the space around it - I've so far always had it against a wall, and it's always frustrated me when working with a larger piece than the top, so this should be more flexible.
I have some bobbin-sanders that fit the drill-press, so I've not needed a dedicated machine, although if I could find the right space and the cash, it would a 'nice-to-have'.
I'll be having a router-table, so again, no real need for a spindle-moulder, thats too industrial for the kind of work I do, also it would frighten the hell out of me using it :)
