renderer01
Hello Graham,
Main dealer says both brands of machine come from same factory in Taiwan.
Rend
Rend
Grahamshed":1xmywwf7 said:duncanh":1xmywwf7 said:The Axminster might look similar to the Killinger lathes but if you compare the models you will see that most of the specs are different - power, capacity, weight, spindle speed, mass.
As for being made in Germany, the Axminster manual contains the following :-
'Manufactured by Kingcraft Machinery Company
Limited/NO.26, Gong Yeh 12 Rd., Da-Li City, Taichung
County, Taiwan'
One advantage for me would be that the Axminster headstock can be moved along the bed and rotated, allowing it to fit better in my small sized shed.
This lathe has been discussed before and the member here who works for Axi confirmed it was from Killinger. The bit about being made in Taiwan is disappointing though.
I stand by everything I said in my previous post. Not found anything that I don't like apart from the two minor gripes that I mentioned ... but then, I'm a hobby turner.renderer01":1dmvfwn1 said:Hello Robbo3, My lathe arrives on Tuesday and I have a quick ish question to ask you.
Is there anything with the benefit of hindsite you would advise regards setting up of lathe.
Are you still as content with the lathe.
I have 2 rather burly young uns coming to help me and I have done all the work and can think of needs done prior to arrival.
Thanks for any information you can give me.
Rend.
I meant to have said the same thing but forgot , however you probably put it more eloquently.renderer01":2p094rx5 said:I tend not to turn much in the way of large pieces and 16 inch diameter is not a common size for me to turn. However it gives me a very easy capability to turn beyond 12inch with much more stability. I do feel that budget and space available play a huge part in the choice of lathe purchased .... rest snipped
Rend.
