Next up - the legs/frame.
I switched to using air dried ash here from Duffield Timber. This stock turned out to have some interesting olive ash type sections which made things a bit more interesting.
Lots of hand planing and then flattening with the thicknesser and the stock was prepped:
I started with the legs using the sled to cut the tapers:
I added the mid sections to the A-frames and then machine cut mortices:
A frame details:
The long stretcher between the two a-frames I wanted to keep as light as possible so I used this sort of 'butted' setup that gets thicker at the joins:
With all the leg pieces done (and time running out as I had less than a week left) I put the frame together with a dry fit and some clamps:
Things look a bit top-heavy here, but the angle is making it seem worse.
And here was the 'told you so moment'. Although things were rock solid front-to-back with the top on, left to right there was a bit to much 'give' for me. So with very little time left, panic set in.
In the end, I opted to go for some thin diagonal braces that were not in the original design. I tried cutting a stretcher piece and just clamping it on to simulate if it would make a difference. It did - it transformed it to rock solid.
At this point the next couple of evenings were a blur, I had to do the final finish fit the draws and make the pulls and add fabric to the bottom of the doors.
I also had to address something I'd been avoiding for a while - the top had started to bow front-to-back! I knew I would have to do something and thought about getting some steel strips. But in the end I went for this solution using strips of ash screwed to the bottom:
This effectively pulled the top back flat. The thickness of these bits didn't matter as they were hidden in the box elements of the desk.
With that sorted the next night was spent finishing up the draw fitting and last minute tweaks. I didn't get the mirror properly attached to the desk lid and failed to do the final attachments of the hood, but it was ready enough to bring into the living room for the final reveal for my daughter:
Final pictures in bedroom:
Overall, I am fairly happy with it - the frame is strong and stable despite it's lack of girth.
There are mistakes and things I'd do differently, but it was very much my first 'proper' piece of furniture.
