So this is the first proper post of the bridge build on the machining side of things, as i have now started taking the tools to the Oak. The Bursgreen UOS over/under has been hammered the last two days, I’ve filled three 1 ton dumpy bags with shavings already, it’s a big shaving that comes off this wet oak as opposed to fine dust so it’s filling up fast.
It starts with my rod, a cutting list and knowing in my head where it’s all going, which I get from the rod.
I’ll apologise in advance as I’ll be in a lot of the photos as they are stills from videos I have been taking for another platform.
I am squaring the fence on the planer ready to machine 4 posts at 150 square and 6 posts at 120 square. It is critical that the posts are 90 degrees, if they are not I’ll be fighting the tide from here and there’s only 1 winner.
Nice and simple to start with, the finish is really nice straight off of the machine. I like to use the Bursgreen for the over and the under as there is virtually no snipe whatsoever even on the really large stuff.
With the posts sorted and not needed until marking/morticing/cutting its onto the next sections, I need 8 bottom rails and 8 hand rails, 100x70 and 100x100 respectively, they have a really gentle curve on them so it’ll be planed, thicknessed and then profiled up on the ring fence for the edges.
You can see from above shot how gentle the rails are, the handrail is running out at a 10m radius so very shallow. This was about the worst of the timber, I can be picky what I cut so I aim for the cleanest section I can
Run it through the mighty 1950 28” Sagar bandsaw, what an immense machine this is, a proper bandsaw that’ll stop at nothing, it’s an old friend of mine now and I very much appreciate it.
Once I’ve cut round them all on the bandsaw (using my templates from the rod that I draw around) it’s time to set up the spindle and ring fence to face them up off the template. Really easy to machine as they are almost straight, so no worries about short grain or block grab from running in a really tight radius etc!!
Basic set up of the machine. This a 4” whitehill block cutting 4” stock, I made it work thickness wise so I could run these out in one pass.
For those who don’t know what the ring fence is or haven’t used one before, they are phenomenal bits of kit for creating curved work. it’s a very versatile tool that I use on a weekly basis.
A terrible picture, again this was taken from a video but it shows the template up against the fence and how it’s worked around. 32 passes sees it all done.
And here’s one straight off the block, it’s a great finish. Once these have been tennoned either end it will be back on the ring fence to put a quarter round on the top edges.
Again I am checking for absolute squareness off the spindle, it’s all set up lovely so it’s bang on. I check every other one as I go, just for peace of mind.
First little bits offered up to the rod to see the lie of the land, I can just check that all the dimensions and the curves are checking out on the 1:1. So far all is well. I will be morticing next, I’ll be sinking an 1” chisel in for the handrails/bottom rails and probably a 7/8 or a 3/4 for the infills, I’ll see what happens on the day. I’ll post that up when I’ve got it done.
Here’s the main beams, some big old hunks of Oak here, really really straight and flat which is a bonus. The short one is 5.3 metres long, 605mm wide and 110mm thick. It’ll be a good job getting these machined out from the template, I’ve got a few ideas in my head, there’s always more than one way to skin a cat and all that caper but either/either they’ll come up a treat I’m fairly confident!!!!
Scotty
