the rod isn’t calculations as such Mike, in most instances the drawing (if I’m lucky enough to get oneOne page of calculations and all set out from a straight line, but I suppose it’s easier to physically set it out if you have the room.
If a story pole is what aids you in making something Pete then I can only assume yes it is! Thankyou for the interest and I hope you enjoy the thread as it unfoldsI'm pretty sure I know the answer Scotty but I'll ask anyway. Is what you call a "rod" what we would refer to as a story pole?
Story pole or stick seems to mean measurements marked out on an actual pole or stick i.e in one dimension. Might have picked up the name from stair-making where you really do need a story height stick to record the floor to floor measurement and to divide it into equal risings.I'm pretty sure I know the answer Scotty but I'll ask anyway. Is what you call a "rod" what we would refer to as a story pole?
Mostly cut and glued to the drawing.Model aircraft making is similar, with struts laid out, cut and pinned to a drawing. How else could you do it?
Both sides stuck too each other - DAMHIK!Mostly cut and glued to the drawing.![]()
I know your question has been answered already and similar questions have been asked here before. I'd call what Scotty's doing is creating a rod, and when I lived in the US I learnt what I knew as a rod was called a story stick.I'm pretty sure I know the answer Scotty but I'll ask anyway. Is what you call a "rod" what we would refer to as a story pole?
Not on this bridge as although it’s big for me on my own, it’s relatively tiny and no issue to get the timber in one piece.Had you (or they) considered laminated beams? Love to try laminating something that large.
Ian
I thought there was a difference because I've seen several youtubes of yanks explaining their "story sticks" as just a one dimensional scale; a stick with marks along it, not a 2 dimensional drawing.I know your question has been answered already and similar questions have been asked here before. I'd call what Scotty's doing is creating a rod, and when I lived in the US I learnt what I knew as a rod was called a story stick.
It's always seemed simple enough to me, i.e., rod, story stick, story pole are essentially the same thing, i.e., stuff set out full size on a stick, a board, or boards, big piece of paper/card or even set out full size on a floor, stage set, etc. But I mentioned above that similar questions have been asked before, and I came to the realisation that for some here in the UK there seems to be real differences between a rod and/or a story stick or pole.
I have to admit I've never been able to get my head around the subtle(?) differences between a rod and a story stick in the mind and the the practice of some British woodworkers, but they seem to be real if I've remembered it correctly. Slainte.
That’s the great thing with the rod Niall, it became apparent quickly the computer had a hard time spitting it out. Sections 1&4 are the same dims and 2&3 are the same, so I’ve made both pairs run the same, it looks ok.Looking at the drawings again, i noticed that where the the arms of the diagonal 'swastika' ( apologies but it's a convenient way to describe the shape) enter posts 2,3,and 4, from either side, they appear to getting progressively closer and closer together.
Now that you have sorted out the rods is this indeed the case, and a result of the asymmetric design of the panels coupled with the curvature of the bridge - or is it just an optical illusion ?
Niall
No worries about the swastika - the Nazis borrowed it but it was used in more benign circumstances for hundreds of years before. Just don't have a tattoo! https://en.wikipedia.org/wiki/Swastika#:~:text=The swastika (卐 or 卍,in the early 20th century.That’s the great thing with the rod Niall, it became apparent quickly the computer had a hard time spitting it out. Sections 1&4 are the same dims and 2&3 are the same, so I’ve made both pairs run the same, it looks ok.
It’s funny you mention the Swastika as we were having a chat about this at the time I was rodding it.
Thanks for the interest
Scotty
I think of a story stick as a rod with the lengths marked on it.I thought there was a difference because I've seen several youtubes of yanks explaining their "story sticks" as just a one dimensional scale; a stick with marks along it, not a 2 dimensional drawing.
Here's the first one I turned up with a search on "the story stick" https://www.google.com/search?q=the...ate=ive&vld=cid:1519f0a2,vid:hsjdWT6gqhE,st:0
Maybe they are all called story sticks one way or another?
Everybody should have a copy! I've got one, I'll have a look.In George Sturt's a wheelwrights shop, it describes how someone sets off to measure up for a well frame and roof (I think, it’s 50 years since I read it). All he took with him was a pencil and a long lat. The problem is I can’t remember what they called the lat. — If anyone has a copy?
It stuck with me and I’ve been doing things this way ever since.
Ian
I knew someone would have a copy! Just hope my memory of the event is correct haha.Everybody should have a copy! I've got one, I'll have a look.
They probably called the lat a "lath"? But not a "story lath".
