Which was the point of my other post in thread do stanley still make a 7.
Seemed a tad beyond many though? there has to be a point where they progress from delicate/fragile and fiddly to set up with coarser parts.
Ok some of the steel/blades was higher quality and got rosewood handles!
They then progressed to a point where the bases are decently cast smooth tight grained square and flat.Frogs cast right.Cap iron works and easy to set.Blade might not be the best but good.Ok maybe not rosewood but of a decent standard and plane works and is reliable in use.
Then the Bean counters land and it all goes tit's up quality is going down fast like your saying about shifting to Mexico and Record to ???
Type1 to Type? must be types in there that are the sweeter spots of plane
I doubt many on here have had a gaggle of types.
I don't know if I've had anything before type 6, but I have had something around there as well as a bunch of 9-11 early on. We were all led to believe here in the states for a short period of time that Type 11 was "the best", which was strange because collectors were paying more for sweetheart types.
"anything with a tall knob won't be as good as type 11". I don't know where those notions come from.
What's good? Type 20 and before. What's not? plans where the frog to casting isn't a continuous surface (later english and now mexico - found out quickly that the current production 7 jointer isn't worth getting).
I've perhaps had 80 or 100? not sure - stanley type planes over the years. I have more than I need now but only a small fraction of that still - 15? 10?
Whatever it is, it's probably 10. I had less trouble with later planes that weren't worn, and far more trouble with earlier planes that were worn or with parts swapped. Thus the comment.
This isn't really a paint by numbers thing, because there's an "and" in it.
A type 11 is a nice plane, but it has to be type 11 and no unusual wear and no improperly switched parts. Parts that were switched that match well, no big deal, but it's more common for someone to have three complete planes and then a bunch of others and do whatever they can to finish out one or two of those and dump them on ebay.
Nobody was using the 8 that I just bought, but this is what the listing said:
This is a vintage Stanley Bailey #8 flat bottom plane in very nice condition. It has a Patent date of April 9 1910. The plane is carrying a Stanley Sweetheart blade.It has been stored away for many years |
It's like the famous line said here about farm equipment. "was running when last parked" (still ran a little with a window in the block and the rear differential is stripped of most of its teeth, but that part, we'll let you find on your own).
https://i.ebayimg.com/images/g/~7UAAOSwENhjXJbX/s-l1600.jpg
hopefully, you can see that image. Can you tell that the handle doesn't fit? i couldn't. If you look closely, you can just barely see that it's about 3/16ths diagonal on the casting, can't be installed straight and it can't be screwed down the whole way.
The one frog screw won't even stay in the casting if you turn the plane upside down, but the seller individually wrapped all of the parts, so that was a secret.
I could return the plane, but I'm not the kind of person who does that if I can work with what I get. This is at the edge of how far I'll go with that - it could be something someone's dad bought 10 years ago.
What chance does a beginner have with this? Toe was very low and it would not plane a matched edge, either, but it would probably have been OK for a jobsite roughly flushing house joints.
