Now i have the a motor and dol starter wired thanks to help from
@guineafowl21 and
@MikeK I can move back to the saw itself, finally!
It took a few days to figure out where i could put it and have any work room left but and this is what i've decided on. Once i have finished working on it i will take it off the wheels and work to get them both flush as one large table. The empty one on the right will eventually become a router table or disk sander.
The current plan for the next few days is to finish turning the oak you see on the lathe to make a temporary fence slide rail and a temporary pulley wheel from some cherry i have laying around so i can see how the bearings sound and take a few test cuts, if anyone can link me to somewhere i can buy a new pulley with metric bore that will match the original ags10 diameter that would be wonderful, otherwise ill find someone local to open it out from 5/8 to24mm. I also want to try and turn down some brass/bronze revolving handles to replace the two on the saw.
Ill take the tops off and clean them both and give the inside a good wire brushing to clear out the old compact sawdust so it moves fully again; i've not counted yet but i reckon this gives
@AndrewS 9 dustpans a run for the money. It came free with the saw under the dust chute/slide.
The other thing, as you can see, is a hole has been cut for dust collection but i've removed and will switch the bottom base section for the other without a gaping rectangle in
At this point i will get it set up properly ready for use until i can get everything for a full resto ready to go in a few weeks
i've already checked inside and all the teeth are intact, everything was well looked after except the micro adjust pinion with was chewed up and worn down most of the length of the teeth so ill buy one from
@deema asap
I will also replace the starter when possible as its not dust proof at all and the buttons are a little small for my liking. Can anyone can recommend a starter that will fit in the old MEM starter box that originally came with the ags' as it would be nice to keep the original look
