bansobaby
Accustomly titled
In the original post the grinder is shown in the same position in both images but rotating in different directions. They can't both be correct unless the grinder has a reversing switch, which would be unusual to say the least.
Which way would you prefer to use a chainsaw, cutting down so that the saw tries to pull away from you, or cutting up so its trying to get at you?
Whoever wrote the manual should be doing something different for a living........
