Advice on running electrics to shed
I'll stand corrected (or sitting at the computer) if wrong but I was taught to never use a coiled cord as it increases the resistance creating heat in the wire coils. Either pull all the cable out of the reel or get a shorter cord instead.
Pretty much any coiled extension lead sold that I have seen in the UK has a rating marked on the side. My 25m cable for example can run 750w coiled or 3000w uncoiled. They often have a thermal overload protection switch as well.
I was at a party last year in an unheated space so someone plugged a 2kw heater into a coiled extension which already had some halogen lights in it. It was quite toasty by the time we noticed. It smelt hot.
OK, seeing as pulling out old OSB in the new workshop is boring, and physics is interesting, I did the test.
2kW filament heater alone:
236.2 V
8.75 A
2058 W
PF: 1.00
2kW heater + 30m coiled extension lead (ten seconds only!):
236.4 V
8.53 A
2071 W
PF: 1.00
As you see, the coiled lead isn’t sucking (or pumping) any VARs. What you say about displacement PF is correct, but doesn’t apply in this case.
Work out the resistances on those two and they differ by about 0.71 Ohms.
That sounds like a reasonable number for the resistance of 2x 30m lengths of copper.
Get a qualified electrician in for the mains
Or
I have fitted my own solar panels battery’s and inverter
Note
If using lithium batts you will prob have to speak to local fire station as when I asked they record lithium battery applications re fire risk
I think this depends upon the number and size of your lithium battery banks, but it is always good practice to put a hazzard warning label on a shed door or place where you have anything that could be classed as a hazzard such as gas bottles or compressed air.
Or
Note
LiFePo4 batteries are, as far as I know, extremely unlikely to catch fire.
I also have a "solar shed". 410w panel, 24v 100ah lifepo4 battery and 4000w pure sine wave inverter. Works for me, but I don't live out there.
Since posting original question, I've had a few more thoughts about this.
First, my current use case includes the following; and has done for over 17 years since we moved in here.
I have a twin socket, coiled reel extension lead that I use regularly. It is labelled for "outdoor use" has 1.5mm2 triple core rubber sheathed cable and is 43 metres fully uncoiled. Labelled as Max Current Fully Coiled = 5A; Max Current Fully Uncoiled = 13A.
I've regularly plugged this into my garage socket and hooked up my shop vac (1000W) and my old Einhell table saw (2000W) - (recently replaced with 1500W Rage5-S)
This would, for a layman, and in the absence of any other further professional advice or warning, appear to be a reasonable thing to do. Notionally, this would not appear to have exceeded any basic electrical parameters. The lawn is 15 metres from the closest garage socket and a lawnmower cable is an extra 10 or 15 metres on top of the 43 metres of extension cable. The garage socket would be the primary choice to run an electrical lawnmower - commonly 1700W or 1800W.
Question would be - is what I've been doing "safe"?? A common homeowner wouldn't have any notion of loop impedance, etc... so would not hesitate to do what I have done for many years.
Bearing that in mind, how would a simple 15metre length of 2.5mm triple core running from the same socket, into a far, FAR lighter electrical load (sub 200W total) somehow be something to be concerned about, given that it ought to have been considered safe, to a layman, to run the 3000W load off a 43 metre 1.5mm2 cable?
That is why some people get themselves into trouble and there are electrical thermal events because they know no different and have no concept of electricity except that it is not cheap. Without any electrical background people do some incredable work because they just do not realise the dangers but when it all works they think they have done a great job because their logic is "it's working so must be safe". Another issue is that they also believe that the fuse is going to protect them, luckily we now have residual current protection so safer from an electrocution perspective but that fuse needs a certain amount of current to actually cause it to blow, if you are pulling almost enough current but not quite enough you have a potential overload and now things get warm.
