Pekka Huhta
Filing the spine was pretty easy, at least compared to the fact that I started with a 8x50 mm brass bar and shaping that to a spine took some time to start with
As you can see I cheated a bit and sawed it with a jigsaw. :wink:
What caused more problems was the transition from oval to square. I could not decide the handle angle and there was a problem getting the transition to the correct place and angle. But when I got that sorted out I did some more cheating and took an angle grinder to rough shape the oval. Then it was time for some filing with a rough mill file. Some polishing with a handheld power grinder (abt 16 000 rpm), still some further filing and some polising with a buffing wheel.
After I got the back shinning, I took several grades of wet-n-dry paper and dulled the surface. I also added a sulphur mixture to patinate the brass and then polished it a tiny bit with steel wool. I love old tools, so I wanted this to start as an "old tool" instead of a shiny, new one :wink:
Pekka
Pekka
